EoIP + Cisco Macsec
Hi all
Does anyone know if Cisco MACsec/Trustsec encryption will function across two Mikrotik routers providing EoIP connectivity between two networks?
This does not work over a L2 VLAN or L2 QinQ connection, which is all the carrier can offer between the sites.
A
Hey Ascendo, and everyone,
Does anyone have an update on this? Will Cisco MACsec work across a MikroTik/EoIP bridge?
Thanks!
It should work fine with the new WAN extensions. With out the WAN extensions it may work but it depends on a how the L2vpn is setup.
