It would be great to have an EoIP client for windows.
EoIP is possible only between two MikroTik routers.
YEA! I know it is now. That’s why I was asking for it.
“anything is possible”
Anything is possible, but this is not planned.
Well, it is bad that it is not planned. What should we do to make it to be planned ? Create some poll, gather some votes, what ?
Would be rather pointless since EoIP is only static point-to-point tunnels (as between two network devices).
I really doubt there will ever be a Mikrotik-developed EoIP client for windows. But if you check github you’ll see there are several projects which have successfully implemented Mikrotik-compatible EoIP on Linux, OpenWrt, etc… So a windows client would just need to be self-developed in a similar way. Nobody’s done it yet probably because it’s easier just to spin up a VM with chr, buy a mikrotik, or an openwrt-compatible router. I agree it could be a useful tool though, hopefully someone develops it
and OpenWRT router ?
MikroTik CHR? You can run it in virtualization software on Windows.
