EOIP Config error or user error
I have the following configuration which is not working.
office1 = Mt with server t1’s installed as gateway for customers. At or new office addational t1’s are in place to add capacity until fiber cutover. I created an eoip tunnel via or wireless network. Then on both ends I created a bridge from the tunnel to an ethernet card. I then added a public it to that interface at office one. When I ping its gateway the traffic will only reply on the bridge not the ethernet card?
Please help
It is unclear what you’re trying to achieve, and what your configuration is.
Post precise goals (not how you think you’re going to achieve the goals - post the business requirements), together with the output of “/ip address print detail”, “/ip route print detail”, “/interface print”, “/ip firewall export”, and an accurate network diagram, as well as the EoIP configuration you have applied so far.
I am simply wanting to transport a few t1’s to the main office via wireless connection then load balance between the t1’s onsite and the few in the tunnel. I will post details once I am at the office
