Good evening
After storm, our hEX Lite on old remote location stopped working. We configured RB493 as replacement, but we faced a problem. EoIP doesn't work with RB493. I updated deviced on both ends and tried different things and nothing working. Only when I change value KeepAlive from 10 seconds to few minutes, they connect between each other and pass mac-adresses between each other but remote hardware unreachable anyway. When I tried reconfigure EoIP tunnel to hAP Lite, tunnel works perfectly without any trouble. What am I missing?
Local end: RB450G(EoIP to different locations, works perfect), RouterOS 6.45.1
Remote end: RB493, RouterOS 6.45.1
Local End configuration:
jul/09/2019 17:00:35 by RouterOS 6.45.1
software id = WTHK-66VY
model = 450G
serial number = 33B601DA3464
add fast-forward=no name=bridge1 protocol-mode=none
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
/interface eoip
add keepalive=10m10s mac-address=02:9B:78:BF:F2:D0 mtu=1500 name=rb493 remote-address=91.203.25.158 tunnel-id=1
/interface vlan
add interface=bridge1 name=vlan_mng vlan-id=50
/snmp community
set [ find default=yes ] name=UNTC
add bridge=bridge1 interface=rb493
set discover-interface-list=all
/interface pptp-server server
set enabled=yes
add address=195.238.176.10/27 interface=ether1 network=195.238.176.0
add address=10.11.9.100/16 interface=vlan_mng network=10.11.0.0
add action=accept chain=input protocol=tcp src-address=94.100.215.0/24
add action=accept chain=input protocol=tcp src-address=195.238.176.0/27
add action=drop chain=input protocol=tcp
add distance=1 gateway=195.238.176.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=94.100.215.0/24,195.238.176.0/27
set api disabled=yes
set winbox address=94.100.215.0/24,195.238.176.0/27
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/snmp
set contact=noc@untc.net.ua enabled=yes location=208 trap-version=2
/system identity
set name=dev-test-perl
/system logging
add action=disk topics=critical
add action=disk topics=error
add action=disk topics=info
add action=disk topics=warning
/system ntp client
set enabled=yes primary-ntp=195.238.176.2 secondary-ntp=195.238.176.6
/tool bandwidth-server
set authenticate=no enabled=no
Remote end configuration:
[noc@dev-test-perl] > export
jul/09/2019 20:01:20 by RouterOS 6.45.1
software id = WNXS-TLED
model = 493
serial number = 2797018DCECF
set [ find default-name=ether2 ] loop-protect=on
set [ find default-name=ether3 ] loop-protect=on
set [ find default-name=ether4 ] loop-protect=on
set [ find default-name=ether5 ] loop-protect=on
set [ find default-name=ether6 ] loop-protect=on
set [ find default-name=ether7 ] loop-protect=on
set [ find default-name=ether8 ] loop-protect=on
set [ find default-name=ether9 ] loop-protect=on
/interface eoip
add allow-fast-path=no keepalive=10m10s mac-address=02:9B:78:BF:F2:D1 mtu=1500
name=rb450g remote-address=195.238.176.10 tunnel-id=1
add bridge=bridge1 interface=rb450g
add address=10.11.0.120/16 disabled=yes network=10.11.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add action=drop chain=input disabled=yes protocol=tcp
/ip service
/ip ssh
set forwarding-enabled=remote
/system clock
set time-zone-name=Europe/Kiev
/system identity
/system logging
add topics=l2tp
/system ntp client
set enabled=no
