I need to set up a EoIP tunnel for remote diagnostics at a customer site (Factory automation, PLCs etc). Customer will physically connect the router port to various LANs as and when required.
Router at the ‘customer’ end will be on cellular, assume dynamic WAN IP. From what little research I have done, I think I need EoIP, over VPN and use some dynamic dns service so i can find the router.
-What mikrotik hardware would be reccommended for this?
-It is not clear to me is if mikrotik router is also required on ‘my’ end- Is it possible to have some kind of virtual NIC running in My PC?
Thanks.
