EoIP interface RX value
Dear All,
I need get the value of EoIP Interface RX value with script, is any body have idea for this script.
BR
I didn’t see a way to get that value in ROS 6.25 from the command line. You may have to use the API. Unfortunately, the API is not something I am any good at, so someone else may have to chime in as to how to accomplish that. :slight_smile:
You can gen interface stats in “/interface” menu not in “/interface eoip”
Ok, great. I was looking in the wrong place. BR, do you still need help then?
Dear All
actually I need to read the just RX value by command and pass it to some variable.
BR
