((sorry if i am posting in the wrong forum)please move my post admin)
How to do EoIP? Yes I know the n00b should start with search the web
But the n00b did not find what he was looking for
So how do I do EoIP?
At my house I got a mikrotik router
At my sister’s house she got a combined modem and router from there ISP
my plan is to put a computer with routerOS on her network and not change any of her devices config. Is that possible (need to talk with her devices at a Layer 2)???
or do I need to put everything behind the computer with routerOS??
Layer2 between two locations that are otherwise independent of each other is almost always a bad idea.
Go for a routed connection instead (use GRE tunnel interfaces, put a /30 of private IP addressing on the link, and route each site’s LAN addresses across the tunnel.
If you use 192.168.1.X/24 at your house and your sister’s house uses 192.168.2.X/24, here’s a quick example of what to do:
Then make sure the NAT rules won’t apply to packets going through the tunnel interfaces, and also make sure that the FILTER rules permit packets in/out of the tunnel interfaces, and you’ll be set.
The #1 reason layer 2 is bad is that both sides will have their own DHCP server, and these will fight each other for supremacy. (Like Highlander, there can be only one) - If you must use layer 2, then perhaps only the device requiring layer2 can be bridged, while the rest of your sister’s LAN can be its own network.
