You need a different MAC address for each end of each EOIP tunnel.
If you use IP address, 1 IP for each device where you connect to.
In your case: 2 tunnels = 4 ports = 4 MAC addresses.
3 devices being connected = 3 IP addresses.
You need to look at EOIP as an ethernet cable.
Every ether port has its own MAC address as well.
In your case it might work since site A has 2 EOIP tunnels starting to B and C.
But logically those MAC addresses should be different. Exactly the same as with an ethernet port.
Look at it from another angle⦠assume Hex with 5 ports.
In its simplest form (used as switch) it has 1 IP address but 5 MAC addresses, 1 for each port.
The MAC address is clear. Thanks
Regarding IP address I assume was not clear enough, so maybe this is the answer to my original question.
you said one IP for one EOIP interface. Actually I did not set IP for EOIP iterface I was talking about the tunnel local address.
So I mixed the two MAC one IP. The IP is for WAN interface and the MAC is for tunnel in the EOIP interface config
