I had some trouble last night with an EoIP tunnel that was established over a wireless link. This tunnel had been working well for some time (months), but after a reboot of Router B (see below) the EoIP tunnel would no longer pass packets greater than 1458bytes in size. Any packets 1458 bytes or less would go right through, but packets 1459 bytes and greater would not make it through the EoIP tunnel. What could have caused this all of the sudden? I have rebooted all four routers below and the problem persists.
[Router A]-----{ethernet}-----[Router B]-----{wireless link}-----[Router C]----{ethernet}----[Router D]
The EoIP tunnel runs from Router A to Router D.
Same problem referenced on your forum with no posted solution:
http://forum.mikrotik.com/t/eoip-tunnel-problems/5425/1
Can anyone suggest a workaround? There are a few other times we have seen this on EoIP tunnels and we really need to get this nailed down.[/url]
