hi, just wondering which is the best way to connect 2 wlan, EoIP or WDS.
What’s the advantage or disadvantage of each?
Thx
Thx
If you can use WDS, do so. It doesn’t require that you change the MTU so you don’t wind up fragmenting ethernet frames into two wireless frames as they go across the EoIP tunnel.
the simple way for creating bridging network is WDS. WDS has a higher bandwidth throughput then eoip. Both (WDS and EOIP) are the same method for creating bridge network.
