Hello, I have a problem with EoIP over PPTP. The issue is that I have established a PPTP connection between two MikroTik devices, A and B (devices can ping each other). I want to create a network connection using an EoIP tunnel for transmitting IP camera data from one location to a recorder in another location.
PPTP Configuration for A:
Local address: 192.168.189.1
Remote address: 192.168.189.2
PPTP Configuration for B:
Local address: 192.168.189.2
Remote address: 192.168.189.1
I configured the channels by setting the local IP to match the local address on the PPTP channel and the remote IP to match the remote address on the channel, with the same channel number.
EoIP Configuration for A:
name=“eoip-tunnel1” mtu=1500 actual-mtu=1500 l2mtu=65535
mac-address=02:6A:E1:A1:1D:78 arp=enabled arp-timeout=auto
loop-protect=default loop-protect-status=off
loop-protect-send-interval=5s loop-protect-disable-time=5m
local-address=192.168.189.1 remote-address=192.168.189.2 tunnel-id=103
keepalive=10s,10 dscp=inherit clamp-tcp-mss=yes dont-fragment=no
allow-fast-path=yes
EoIP Configuration for B:
mac-address=02:1A:F0:90:9B:35 arp=enabled arp-timeout=auto
local-address=192.168.189.2 remote-address=192.168.189.1 tunnel-id=103
allow-fast-path=yes
The EoIP channels are added to the bridge on both sides.
Unfortunately, the channel does not want to establish itself, and the bridge has the interface status as a disabled port. I have reviewed several manuals and videos on configuration, and theoretically, it should work right away, but it’s not working. Any ideas? Version OS 7.8.
Thank you in advance for your help.
