Hello!
Need help with something i never touched before.
What i’m trying to achieve:
Bridge two networks for flawless access between them. No issue here, just add EoIP or IPIP and setup one route - it just works. Additional thanks to MT team for adding “use IPSec” flag in some interfaces types, it helps so much!
But on side A, there is alot of broadcast traffic i want to get on Side B. All apps send broadcast to standard 224.0.0.0/4 subnet.
Ideally, i want broadcasts from site A going to site B and vice-versa. All that without using bridges on site A (last time i tried, bridges wasn’t playing well with VRRP). I can configure any type of tunnel between this two nodes, but it also should be encrypted (right now i’m using IPSec encrypted IPIP).
i can probably use routing → PIM for that task, but i’m not sure. I’m not a network guy.
install info if that matters:
Site A: Mikrotik RouterOS 6.36, x86 VM, subnet 192.168.11.0/24. There is actually two routers, configured for VRRP fallback. No bridges, 3 VLANs, whole network is routed (just 2 physical interfaces - 1 for WAN, 1 for LAN and around 10 virtual - VRRP, VLAN interfaces, 6in4, etc).
Site B: Mikrotik hAP AC, RouterOS 6.36, subnet 192.168.12.0/24. No advanced stuff. 1 WAN port, 4 port (and 2 wlan interfaces) in bridge for LAN. Great tiny router btw, will fit anywhere.
Both routers configured with static IPs, using different ISPs, no filtering on ISP side and i can use any protocols and ports. 100 mbps line between them, latency is around 3-4ms between points (same city)
