EOIP Ping Time Problem
Hi
I have 2 mikrotik router (router A and router B).
Between these 2 routers, I have 3 wireless links. I created an EOIP tunnel between router A and router B.
The latency between router A ip address and router B ip address is always under 10 ms, but sometimes the latency between EOIP tunnel A and EOIP tunnel B is up to 600 ms.
Does anyone know what is the problem?
Regards
check the wireless links - how good they are what rates are selected etc.
The wireless links are always OK.
I think it is a popular problem with mikrotik EOIP tunnels.
Not noticed this. EOIP needs some CPU. Maybe your routers are to busy/slow?
What kind of wireless link are you using?
  • Mat
