I have the following configuration:
→ one site with Mikrotik and direct connection to Internet with fixed IP
→ one site with Mikrotik but transparent NAT done in fiber box (I can’t for now remove the box or put in pass-through mode)
I need to link both sites through VPN so I can use same IP class so is it possible to do (http://wiki.mikrotik.com/wiki/Manual:Interface/EoIP) EoIP VPN between two sites ? or it won’t work due to forced NAT on one side ?
EoIP is basically a GRE tunnel. So if you do a proper destination NAT for protocol GRE on each NAT box is should work flawless (on one side in you case - if your fiberbox allows this).
If it doesn’t, you can fallback to a client/server configuration like PPtP or OpenVPN, with the server component running on the exposed Mikrotik router.
hum I’m trying to setup it following wiki instructions but I’m confused at one of the last steps:
[admin@Our_GW] interface bridge> port add bridge=bridge1 interface=office-eth
I suppose I should replace office-eth by my local wan port, right ? I tried to put instead ether1-gateway which is my wan port but it doesn’t work it states “device already added as bridge port” !
Thanks for all your advices, my only issue is I have been unable to setup correctly the eoip as I asked for help about one parameter I need to setup according to wiki but never got any help
