Hi all,
we are planning to replace a low-bandwidth old frame relay (?? not even sure it is really a frame relay) line between two offices with a VPN.
Since we use the same network on both ends, we are thinking on EoIP.
I each of the offices we have two Internet connections with different ISPs, and not load-balanced but being two gateways. We manually use one gw or the other in different places or change them according to the circumstances.
Now the question: does the router having the EoIP tunnel need to be the gateway for the devices using the tunnel? Or is it pure layer 2 and the router will “catch” all the frames for devices at the other end and pass them on?
Thanks in advance.
Gerardo.
