EOIP site to site only half working
VPN was not working for our remote office so we went with EOIP with OSPF
we have a 172.19.0.0/19
at our remote office, we can access any static IP on the 172.19.0.0./19
but our CPE’s (We are a WISP) get DHCP from Pool 172.19.10.0 - 172.19.12.0/19
anything in that DHCP Pool we cannot access from our remote office
would this be a missing firewall rule?
I’m a bit new with Mikrotik we had a consultant set up the EOIP but he is a bit busy
also would like to learn how to do all this my self
Thanks in advance for any help
an update
I can ping the DCHP Pool from our remote office inside the Mikrotik terminal
but not behind the NAT that is assigned to my laptop
Can you provide more info?
  1. I understand that EoIP tunnel between main and remote office is up. Are you using L3 (both ends of EoIP tunnel have IP address?)
  2. What is LANs IP addressing on both sides? (main, remote) you want to communicate.
  3. Please explain where network 172.19.0.0/19 is assigned ? WAN, LAN?
    Maybe draft diagram will help? :slight_smile:
  4. If you are using OSPF you should see other ends networks on route list (IP->ROUTES) You can also add LOG Rule for OSPF and see any OSPF logs.
172.19.0.0/19 is the LAN side of our core network
EOIP tunnel is 10.10.10.0/29
LAN Side of remote office is 10.0.0.0/24
if I give my laptop a static on 10.10.10.0/29
all works as it should
but on the IP Pool (DHCP) 10.0.0.0/24 we can only talk to static IP’s in the core network not to any of the DHCP POOL
seems as if we are missing a bridge or firewall rule to connect the EOIP tunnel 10.10.10.0/29 Pool to our Local NAT Pool of 10.0.0.0/24
Some things are still not clear: do you have your tunnel bridged with LAN only on one side or on both sides?
the tunnel is a bridge to the Core network side 172.19.0.0/19
I need to bridge the EOIP tunnel IP to my Local NAT (I Think) but not sure how to do it
if I set my laptop a static on the EOIP Tunnel range everything works perfectly
I just need a DHCP Pool on the remote Mikrotik that bridges the EOIP tunnel pool
our DHCP pool right now on the remote network is only half working
but if I use the Static out of the EOIP Pool it works perfectly but consultant only set that up with a /29
and we need more IP’s then that for our remote office
Please post an export from both routers.
nope not will all the Mikrotik security holes lately
I created a guest vlan trying to block it and the vlan works perfectly so I think I just need to create a vlan for it
thanks
  1. EoIP tunnel has 2 ends, so no reason to use /29 mask. I suggest to use 10.10.10.1/30, 10.10.10.2/30 and forget about connecting anything within this ip range. Additionally I recommend to enable IPSEC on EoIP tunnel.
  2. If you are using only this one EoIP tunnel, use static routing instead of OSPF. This way you have better control.
MAIN OFFICE MIKROTIK:
add distance=1 dst-address=10.0.0.0/24 gateway=10.10.10.x
#where 10.10.10.x is the IP of EoIP tunnel on REMOTE OFFICE MIKROTIK
REMOTE OFFICE MIKROTIK:
add distance=1 dst-address=172.19.0.0/19 gateway=10.10.10.y
#where 10.10.10.y is the IP of EoIP tunnel on MAIN OFFICE MIKROTIK
Because you are using layer3 tunnel, no bridge is needed. It works almost like Site-To-Site VPN.
If you have any firewall rules, be sure traffic between 172.19.0.0/19 and 10.0.0.0/24 is not dropped (denied) by any of these rules.
Hopefully it will help you fix the issue !
Thanks for the help
Issue was an IP conflict with the NAT side of our CPEs changed the office IP range to 192 and working perfectly now
Now my issue is no matter what I do to lock down the guest VLAN to block access to the main network it can still reach the router other side of the EOIP I will play with adding drop rules to that router tomorrow
Just odd I told it to drop anything from 192.168.25.0/24 to 172.19.0.0/19 and it blocks all access to 172 exept the router on that network and guest can still ping anything on that network
Been searching all over Google for the firewall rules I’m missing but nothing yet
is there a way to stop inter VLAN routing on the guest VLAN?
Seems like that should be default
This can be solved with firewall rules.
There are a lot of examples how to build good and simple firewall so you will definitely find something what fits your scenario.
My recommendation, or I should say Mikrotik’s Gurus recommendation :slight_smile: is to use address lists and use them with firewall rules (not IP directly) so this way you can easily control traffic in future.
Good luck !
