Eoip through another Eoip
I have a situation that needs one EOIP tunnel to be channeled through another EOIP tunnel.
As far as I see it, it should not be a problem, but before I commit to this in production enviroment, I would like to know if somebody can confirm that there would be no problems with that configuration. On every device is latest 3.x ROS .
Why don´t you use VLANs instead of putting extra overhead from another EOIP tunnel?
/Henrik
Yes, the EoIP in an EoIP should work just fine. You’re overhead will be huge due to the extra 84 bytes per packet. Make sure you have TCP MSS adjustments in place to minimize fragmentation.
You can try M3P, this could help you.
Max
