Can I build a eoip-tunnel with on one side a nat rule masquerade? If so, how should I do that?
I can build an eoip tunnel without nat rule.
From your post is difficult to understand what you want to achieve, give us an example, please.
I want to build a eoip tunnel between two nodes, Node 1 = 192.168.100.0/24 Node 2 = 192.168.101.0/24 Node 2 is natted and masqueraded to 10.0.0.0/24 I want now use as common 10.0.0.0/24 range but that is natted can eoip tunnel through the wet?
