Version 7.1.3
CCR1036-8G-2S
I have a simple EOIP tunnel set up (per configs below) that behaves sporadically.
Symptoms on Linux PCs:
- Download 3.4 Gb ISO from Internet = download speed 40-50Mb
- Cancel download and try again - download speed 300-500 Mb
- Download a few minutes later = Download speed 300 Mb+, then Failed-Network error warning.
- Download a few minutes later = Download speed 40-50Mb
- Download same ISO from Windows server, across vlans and WAN= Download speed 300+ Mb
- Running same tests on a Windows Laptop (download from Windows share) shows download speeds up to 47MB, but halfway through speeds drop to 0 and start climbing again after 30+ seconds of nothing.
Master:
# may/04/2022 20:37:14 by RouterOS 7.1.3
# software id = IHD4-H4MR
# model = CCR1036-8G-2S+
add name=B703
add name=B704
add ingress-filtering=no name=trunk protocol-mode=none vlan-filtering=yes
/interface eoip
add loop-protect=off mac-address=02:97:91:21:41:0E name=eoip-tunnel1 \
remote-address=10.1.1.2 tunnel-id=7
/interface vlan
add interface=trunk name=vlan703 use-service-tag=yes vlan-id=703
add interface=ether2 name=vlan703-acc vlan-id=703
add interface=trunk name=vlan704 use-service-tag=yes vlan-id=704
add interface=ether2 name=vlan704-acc vlan-id=704
/port
set 0 name=serial0
set 1 name=serial1
add bridge=trunk interface=eoip-tunnel1
add bridge=trunk interface=ether2
add bridge=B703 interface=vlan703
add bridge=B703 interface=ether3
add bridge=B703 interface=vlan703-acc
add bridge=B704 interface=vlan704
add bridge=B704 interface=vlan704-acc
add bridge=B704 interface=ether4
/interface bridge vlan
add bridge=trunk tagged=trunk,ether2 vlan-ids=703,704
add address=10.1.1.1/27 interface=ether1 network=10.1.1.0
/ip dhcp-client
add interface=ether8
/system identity
set name=Master-EOIP
Client:
# may/04/2022 19:08:36 by RouterOS 7.1.3
# software id = MPIL-B0WN
add name=B703 protocol-mode=none
add name=B704 protocol-mode=none
add ingress-filtering=no mtu=1500 name=trunk protocol-mode=none \
vlan-filtering=yes
/interface eoip
add loop-protect=off mac-address=FE:35:A9:BE:03:2F mtu=1500 name=eoip-tunnel1 \
remote-address=10.1.1.1 tunnel-id=7
/interface vlan
/port
set 0 name=serial0
set 1 name=serial1
add address=10.1.1.2/27 interface=ether1 network=10.1.1.0
/ip dhcp-client
/system identity
set name=Client-EOIP
/system logging
add topics=interface
