EOIP Tunnel
Hi forum member..
Any one can help me what is my EOIP tunnel problem im pretty sure my EOIP Tunnel configuration is correct but some how i cant ICMP/ping my computer client at Office-2… also no firewall at all both router.
This my sample ICMP from offce-1 “192.168.10.8” is my local server and “192.168.10.58” is my client Computer
192.168.10.8 is my local Server at office-2 ICPM from office-1
[root@Office-1] > ping 192.168.10.8
HOST                                     SIZE TTL TIME  ST
192.168.10.8                               56  63 5ms
192.168.10.8                               56  63 4ms
192.168.10.8                               56  63 9ms
192.168.10.8                               56  63 3ms
    sent=6 received=6 packet-loss=0% min-rtt=3ms avg-rtt=4
192.168.10.58 my user computer at office-2 and this computer is active at the time when we do the ICMP
[root@Office-1] > ping 192.168.10.58
HOST                                     SIZE TTL TIME  STATUS
192.168.10.58                                           timeout
and from office-2 ICMP/ping to all active user at office-1 its working fine.
im sorry for my bad english thank you…
Hello, you should post your config if you need help.
i will sir
Office 1
address
 #   ADDRESS            NETWORK         INTERFACE
 0   XXX.XXX.XXX.XXX/29   XXX.XXX.XXX.XXX  ether1-wan-1
 1   XXX.XXX.XXX.XXX/29   XXX.XXX.XXX.XXX   ether2-wan-2
 2   192.168.10.254/24  192.168.10.0    ether3-LAN
 3   20.20.20.1/30      20.20.20.0      eoip-tunnel-senior
EoIP Tunnel
 2  R name="eoip-tunnel-senior" mtu=auto actual-mtu=1458 l2mtu=65535
      mac-address=02:F2:D4:5A:28:6D arp=enabled local-address=0.0.0.0
      remote-address=XXX.XXX.XXX.XXX tunnel-id=2222 dscp=inherit
      clamp-tcp-mss=yes dont-fragment=no allow-fast-path=yes
routes
 0 A S  0.0.0.0/0                          XXX.XXX.XXX.XXX             2
 1   S  0.0.0.0/0                          XXX.XXX.XXX.XXX            3
 2 ADC  20.20.20.0/30      20.20.20.1      eoip-tunnel-senior        0
 3 ADC  XXX.XXX.XXX.XXX/29   XXX.XXX.XXX.XXX   ether2-wan-1            0
 4 ADC  XXX.XXX.XXX.XXX/29   XXX.XXX.XXX.XXX    ether1-wan-2            0
 5 ADC  192.168.10.0/24    192.168.10.254  ether3-LAN                0
 6 A S  192.168.20.0/24                    20.20.20.2                1
office 2
ip addresses
 0   ZZZ.ZZZ.ZZZ.ZZZ/29  ZZZ.ZZZ.ZZZ.ZZZ  ether2-wan1
 1   192.168.20.254/24  192.168.20.0    ether3-LAN
 2   ZZZ.ZZZ.ZZZ.ZZZ/28  ZZZ.ZZZ.ZZZ.ZZZ  ether4-wan2
 3   20.20.20.2/30      20.20.20.0      eoip-tunnel-junior
EoIP Tunnel
0  R name="eoip-tunnel-junior" mtu=1500 l2mtu=65535 mac-address=02:F0:21:45:FB:21 arp=enabled local-address=0.0.0.0 remote-address=ZZZ.ZZZ.ZZZ.ZZZ tunnel-id=2222
 0 A S  ;;; wan1
        0.0.0.0/0                          ZZZ.ZZZ.ZZZ.ZZZ          2
 1   S  ;;; wan2
        0.0.0.0/0                          ZZZ.ZZZ.ZZZ.ZZZ          10
 2 ADC  20.20.20.0/30      20.20.20.2      eoip-tunnel-junior        0
 3 ADC  ZZZ.ZZZ.ZZZ.ZZZ/29  ZZZ.ZZZ.ZZZ.ZZZ ether2-Biznet             0
 4 A S  192.168.10.0/24                    20.20.20.1                1
 5 ADC  192.168.20.0/24    192.168.20.254  ether3-LAN                0
 6 ADC  ZZZ.ZZZ.ZZZ.ZZZ/28  ZZZ.ZZZ.ZZZ.ZZZ  ether4-Lintas             0
like i said sir normal configuration no firewall etc only NAT masquerade…
So your LAN at each location are in different networks. EoIP is used to stretch layer 2 between locations. Your initial post suggested this is what you were trying to do with 192.168.10.8 and 192.168.10.58.
If this is the desired functionality, create a bridge on each offices MikroTik. Add the EoIP tunnel as a bridge port on each MikroTik. Add the Ethernet interface used for your LAN as a bridge port. Move the IP from the Ethernet interface to the bridge interface. Change Office 2’s IP to 192.168.10.253 to avoid a duplicate.
You may find this post interesting as I demo EoIP stretched between 3 offices here:
http://forum.mikrotik.com/t/eoip-problem/107859/1
