eoip tunnel
Who can tell me exactly how to proceed in order to create a eoip tunnel to two router boards.
I used eth2 by both routerboards (wired) eth2 rb1 get ip 192.168.50.1/30, eth2 rb2 get ip 192.168.50.2/30
I’ve seen the wiki but do not understand.
Pleace help me.
Adding EoIP is so simple, please specify which part you don’ t understand
http://wiki.mikrotik.com/wiki/Manual:Interface/EoIP#Setup_examples
Tnx for the reacting.
Do I have to work with existing IP addresses or create new?
Which remote IP’s should I use?
You have to use those ip addresses that are directly reachable.
Tehen add new ip addresses to eoip interface, if you want to route traffic over the tunnel.
