I have a few EoIP tunnels set up, all working great. I’ve noticed that they’re reporting as 10mbit via SNMP, even if they’re capable of more. Obviously this isn’t a major issue, but it does create false positive alerts in my monitoring systems. Is there any way to change the reported bandwidth?
I have a similar problem with interfaces that auto select to 1gb. MRTG still reports 100mb, it seems that SNMP does not check for actual connected speed but reports what is under the ethernet setting instead. Setting the default speed to 1gb solved it, but if the interface now autoselect to 100mb MRTG would not detect it.
Ping. Please Mikrotik? Can we get the ability to assign a speed to a gre-interface so monitoring/reporting works correctly?
