EoIP- two locations in the same subnetwork.
I have tried to put EoIP so that the two locations would be in the same subnetwork.
Both of them get the ip address but the ping doesn’t work from one side to the other.
What else should I add so it works correctly?
Router1
    add fast-forward=no name=bridge1
    set [ find default-name=ether1 ] name=ether1_WAN
    set [ find default-name=ether2 ] name=ether2_LAN
    /interface eoip
    add !keepalive mac-address=02:1D:2F:68:FB:7C name=eoip-tunnel1 remote-address=192.168.11.2 tunnel-id=1234
    add name=dhcp_pool0 ranges=10.10.10.2-10.10.10.25
    add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
    add bridge=bridge1 interface=eoip-tunnel1
    add bridge=bridge1 interface=ether2_LAN
    add address=192.168.11.1/30 interface=ether1_WAN network=192.168.11.0
    add address=10.10.10.1/24 interface=ether2_LAN network=10.10.10.0
    add address=10.10.10.0/24 gateway=10.10.10.1
    add action=accept chain=input protocol=gre
    /system identity
    set name=Router1
Router2
    /interface eoip
    add !keepalive mac-address=02:71:A6:F8:7A:2C name=eoip-tunnel1 remote-address=192.168.11.1 tunnel-id=1234
    add address=192.168.11.2/30 interface=ether1_WAN network=192.168.11.0
    /system identity
    set name=Router2
