EoIP with IPsec
I’ve just tried setting up an EoIP (+ IPsec) tunnel between our office and our datacenter network using a hardware and a virtual mikrotik router.
I’m trying to do this since our 3CX PBX is hosted there and we are trying to avoid NAT, so a direct layer 2 tunnel seems to be the way to go.
The office is behind NAT, so I forwarded and opened GRE, ESP, UDP 500 and UDP 4500
I noticed the datacenter is dropping GRE packets (most probably because of some way OpenStack handles GRE in VXLAN), since I was able to create a GRE tunnel between two offices but not to the datacenter, so I tried encapsulating it in IPsec by just setting the same “ipsec-secret” on both EoIP tunnels.
However now I’m getting on the office router:
ipsec,info initiate new phase 1 (Identity Protection): RouterOfficePublicIP[500]<=>RouterDatacenterPublicIP[500]
ipsec,error phase1 negotiation failed due to send error. RouterOfficePublicIP[500]<=>RouterDatacenterPublicIP[500] somevalue:0000000000000000
and on the datacenter router:
ipsec,info initiate new phase 1 (Identity Protection): RouterDatacenterPublicIP[500]<=>RouterOfficePublicIP[500]
ipsec,error phase1 negotiation failed due to send error. RouterDatacenterPublicIP[500]<=>RouterOfficePublicIP[500] somevalue:0000000000000000
So first of all, is mikrotik even encapsulating GRE in IPsec using this method or is it the other way round?
Second, am I missing anything? Maybe some port? I enabled logging for all dropped packets but couldn’t notice anything off.
Also, the max usable MTU in the datacenter network is 1450, which I had to set manually on the interfaces of the virtual router for it to work, do I have to set the same (or less) for the EoIP tunnel or can it be 1500?
On office router, which doesn’t really have RouterOfficePublicIP assigned to it, you didn’t set tunnel’s local address to RouterOfficePublicIP, did you?
I did set the public IP that does the DNAT, does it require the routers local IP?
Yes, use the local IP (only as local address on office router of course) and you should get better results.
Derp, thanks, that fixed it :laughing:
