EOIP?
Hi, i need to make a setup like this:
i have one mikrotik rb750 as main router with public ip address (server)
i have another 2 rb750s as clients with wan port connected to internet (4g).
what i need to achieve is to make devices A and B on the clients sites visible to each other as if they where in one switch with ip addresses from same subnet.
Am i right with EOIP option? can somebody help me with config?
Thanks, S.
Pretty much yeah. You should create GRE tunnel from site to site.
Hi.
I think, your 4G provider didn’t gave you a static IP-address. In this case, I recommend you any client/server configuration (PPTP, SSTP, L2TP, OVPN) connecting to the main site. Over that connection, you can create an EOIP tunnel.
Regards: Xen
