Hallo,
is there a End of Life date for current Mikrotik Routers? Specially the CRS1072?
After the Desaster at Unifis USG-XG-8 i Wanne sure to buy a product with future support and upgrades for the next time…
Matt
Hallo,
Matt
The CCR series will be kept up to date for the foreseeable future. It’s a powerful device and will be able to use the latest software versions for years to come.
It might be superseded by something else as the “top end” device at some point, but will remain fully functional, compatible and up to date.
Hi Normis, does this include the likely kernel change envisioned/required for v7 and beyond. I am linux and kernel challenged (if you don’t count my extraordinary culinary skills at making popcorn) and thus don’t grasp the challenges of limitations that upgrade may impose. Part 2 of the question is lets say the HEX router doesnt have enough puissance for V7, would there be a trade-up program in place (reduced cost) for current owners?
Thanks for your Answer!
Can you say something about new Versions (RouterOS 7)? Would there a Version for the CRS1072?
I have already answered it in my above post.
Ok, thank you! ![]()
