EPON & GEPON Support for Mikrotik
Is it possible in the near future mikrotik will support EPON and GEPON standards?
Thanks,
TCC
Already supports. Mikrotik introduces the GEPON SFP module which you can use in any Mikrotik Router having SFP cage and its just plug and play.
Here it is
https://mikrotik.com/product/SFPONU
Sent from my SM-N910T using Tapatalk
Link you posted is GPON and it is not same as GEPON. And at the moment Mikrotik doesn’t suport EPON or GEPON.
Is mikrotik planning to support EPON or GEPON in the future?
