how can i use the example on the manual “Equal bandwidth sharing among users” on load balanced MT.
thanx
thanx
follow the links it will help u
http://www.mikrotik.com/testdocs/ros/2.9/ip/route.php
Configuration depends on your load balancing scenario, but probably you can use the configuration example as it is posted on the documentation, mark the traffic for the hosts and use ‘global-in/global-out’ as interfaces.
