Thanks Guys
If you would please help me out with a string of commands i can copy into console, I cant get this working.
Fewi, here is the info you require.
0 address=192.168.50.1/24 network=192.168.50.0 interface=ether1
actual-interface=ether1
1 D address=41.162.7.20/32 network=2.0.0.252 interface=pppoe-out1
actual-interface=pppoe-out1
0 ADS dst-address=0.0.0.0/0 gateway=2.0.0.252
gateway-status=2.0.0.252 reachable pppoe-out1 distance=1 scope=30
target-scope=10
1 ADC dst-address=2.0.0.252/32 pref-src=41.162.7.20 gateway=pppoe-out1
gateway-status=pppoe-out1 reachable distance=0 scope=10
2 ADC dst-address=192.168.50.0/24 pref-src=192.168.50.1 gateway=ether1
gateway-status=ether1 reachable distance=0 scope=10
NAME TYPE MTU L2MTU
0 R ether1 ether 1500 1526
1 R wlan1 wlan 1500 2290
2 R pppoe-out1 pppoe-out 1480
may/12/2011 18:53:20 by RouterOS 5.0rc11
software id = 6PWX-DEZ3
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=
“place hotspot rules here” disabled=yes
add action=accept chain=input comment=“Allow Winbox” disabled=no dst-port=
8291 protocol=tcp
add action=add-src-to-address-list address-list=“port scanners”
address-list-timeout=2w chain=input comment="Port scanners to list "
disabled=no protocol=tcp psd=21,3s,3,1
address-list-timeout=2w chain=input comment=“NMAP FIN Stealth scan”
disabled=no protocol=tcp tcp-flags=fin,!syn,!rst,!psh,!ack,!urg
address-list-timeout=2w chain=input comment=“SYN/FIN scan” disabled=no
protocol=tcp tcp-flags=fin,syn
address-list-timeout=2w chain=input comment=“SYN/RST scan” disabled=no
protocol=tcp tcp-flags=syn,rst
address-list-timeout=2w chain=input comment=“FIN/PSH/URG scan” disabled=
no protocol=tcp tcp-flags=fin,psh,urg,!syn,!rst,!ack
address-list-timeout=2w chain=input comment=“ALL/ALL scan” disabled=no
protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
add action=drop chain=input comment=“dropping port scanners” disabled=no
src-address-list=“port scanners”
address-list-timeout=2w chain=input comment=“NMAP NULL scan” disabled=no
protocol=tcp tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg
add action=add-src-to-address-list address-list=ssh_blacklist
address-list-timeout=1w3d chain=input connection-state=new disabled=no
dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3
address-list-timeout=1m chain=input connection-state=new disabled=no
dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2
dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1
add action=drop chain=input comment=“drop ssh brute forcers” disabled=no
dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=dst-nat chain=dstnat comment=“HTPC PORT 80” disabled=no dst-port=
9091 protocol=tcp to-addresses=192.168.50.104 to-ports=80
add action=dst-nat chain=dstnat comment=“Forward Port 9090 to NAS” disabled=
no dst-port=9090 protocol=tcp to-addresses=192.168.50.102 to-ports=9090
add action=masquerade chain=srcnat disabled=no src-address=192.168.50.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
Thats everything you asked for.
THANKS in advance
