What equiptment I should use?
And how to set up?
I was thinking which nstreme to use ,
I want to use routerboards.
How many bw can i get?
Thank you.
And how to set up?
Thank you.
nsream2 must be your choice, that will make you about 40Mbps of data up+down if you add more you will get more bw
Can i use nstreme2 with routerboards?
Shalll i use rb-133?
Is there any benchmark using
Dual nstreme2 with 4 R52 and 2 RB1XX ?
for nstreme you need at least 1 ghz system
we have 500m link with PII/400MHz secondpards… works fine @30-37Mbps and max. 50% cpu usage.
but long range links we have never try with rb or even lower than 1GHz systems.
regards,
C. G.
