Erase configuration [Resolved]
I own a routerboard RB751.
I want to have an “empty” configuration (no interface configured, no IP Address, and so on): as in a virtual machine for example.
On a previous version, after a material reset, a windows permit to launch a script that clear all the config. By now (v5.14), this window don’t seems to appear:
  • I’ve put a piece of wood in the reset hole,
  • I’ve powered off the router,
  • I’ve powered on the router,
  • I’ve waited all leds to switch off
  • I’ve put out the piece of wood out of the reset hole.
I’ve connected to 192.168.88.1 with winbox.exe, but the windows with script don’t appear.
Thanks for all.
Best regards.
/system reset-configuration
then say yes, after reboot the option will apear
or, even faster
/system reset-configuration no-defaults=yes
Yes, it works.
Thanks for all.
