Erratic latency RB1200 and IPsec multi wan
I have a RB1200 with v5.7 with the following configuration:
eth10 - DSL modem
ppp1 - over this interface to ISP1
eth9 - DSL modem
ppp2 - over this interface to ISP2
eth1 - LAN
I have been running with this for approx 2.5 months without a problem with minimal traffic going over ppp2/eth9 (10-20kbps). I’ve just cut across an IPsec tunnel over ppp2 and now it’s usage is ~500kbps (the max link rate is 900). Since doing this latency is extremely erratic and the ppp over eth9 even disconnects).
Further to this, my IPsec appears to not honour the routing table ??.
I have, a static route going to remote x.x.x.x via interface ppp2
at the remote end it receives the policy with ppp2 ip address in it but from ppp1 ip address.
update:
I upgraded to ros 5.11 and the latency problems aren’t apparent anymore.
Now I need to figure out the routing problem, still cant see why it’s happening.
