Hello
i upgrade my usermanager server to 3.13 now when i try to enter the usermanager i got Error 404: Not Found, also i having issue clients auth with the usermanager
thanks
Hello
thanks
did you remember to load upgraded User-Manager package?
Check system/packages… if it does not show, just FTP (via binary) the corrasponing user-manager version (yes the must match) and reboot… all should be good in the hood…
Thanks for the answer
What will happend it all configuration that i have in the server?
