Error 619, connecting VPN PPTP
dear friends,
i like to ask about mikrotik VPN PPTP Service. I got RB450, OS 3.10. I can connect to PPTP Server locally (using winxp), in the same network segment. But when i connect trough the internet, i cannot connect. And it keep saying error code 619, which said that the port is blocked or something.
image:
i’ve try lot of thing to do.. but it fail..
my mikrotik configuration :
http://www.topimerah.com/vpn.txt
any idea how to solve the problem ?
Please, verify that your Internet router supports PPTP connection passthrough or your router does not have any filter for PPTP connections.
i use Dlink DSL 520T
and to connect to mikrotik.. i use DMZ, so its totally plain
so i connect the internet using ADSL modem, then i do DMZ to my mirkotik, its a clean ADSL Setting
i’ve try to use bridging mode, but i get the same result
solution :
i change from PPTP to L2TP…
case close…
