What this error means:
ether5: bridge port received packet with own address as source address SOME MAC probably loop.
I find “SOME MAC” on local bridge and try to change it. But after minute or two new same error in log with mac I just change.
post your config please
In our experience, that problem is caused by damaged ethernets. The ethernet maybe working or not, but the symptom is always the same, it links either it has a cable pluged or not (I mean that the link led is turned on even if the ethernet does not have a cable pluged).
Of course you also have to consider a real loop in your network as a possibility
Good Luck
