error conect pppoe-server
hello, does anyone know why the new antenna sxt sq ac 5 does not connect me to the server pppoe-server and the old sxt lite ac 5 yes ?,
I have used the same configuration. “export file = backup.txt” and I have pasted it in the new sq.
Hello , we had the same problem before did you upgrade
Gesendet von iPhone mit Tapatalk
Hello We had the same problem before , did you update the sxt to the newest version ?
After we upgrade the sxt connect as usual , you can export config here if you want .
Best regards
hello friend.
if I updated the antenna.
I attach the configuration in a file.
The antenna if I register in the ap but is not able to up the ppoe client interface
tueda.rsc (3.93 KB)
I will take a look and tell u what’s wrong
there is something wrong with this file , i could not understand anything of it , on the sxt go to new terminal and type in export then copy paste here all the result.
thank you
I have exported the configuration of a SXT Lite Ac 5 that works perfectly. To use it in an SXTsq I have replaced wlan2 → wlan1 because the SXTsq only has Wlan1
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] band=5ghz-a/n/ac country=spain
default-authentication=no disabled=no nv2-preshared-key=ajaja7**e
nv2-security=enabled radio-name=cliente353 ssid=“”
wireless-protocol=nv2 wps-mode=disabled
/interface pppoe-client
add add-default-route=yes default-route-distance=0 disabled=no interface=wlan2
name=pppoe-out1 password=prueba use-peer-dns=yes user=usuarioprueba
add exclude=dynamic name=discover
/ip hotspot profile
add name=dhcp_pool1 ranges=192.168.1.100-192.168.1.254
add address-pool=dhcp_pool1 disabled=no interface=ether1 name=dhcp1
set discover-interface-list=discover
add interface=ether1 list=discover
add interface=wlan1 list=discover
/interface wireless connect-list
add comment=“SECTOR PRINCIPAL” interface=wlan2 security-profile=default ssid=
CB.3B wireless-protocol=tdma
add comment=“SECTOR BACKUP” interface=wlan2 security-profile=default ssid=
CB.00 wireless-protocol=tdma
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
add address=192.168.0.3/24 interface=ether1 network=192.168.0.0
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
set allow-remote-requests=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=internal
add interface=pppoe-out1 type=external
/ppp secret
add disabled=yes local-address=192.168.3.1 name=ppp password=ppp
remote-address=192.168.3.2
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Madrid
/system identity
set name=cliente353
/system ntp client
set enabled=yes primary-ntp=10.40.0.10 secondary-ntp=150.214.94.5
/system routerboard settings
set silent-boot=no
