I am trying to connect from a vps to my Mikrotik server over L2TP/IPSec with preshared key.
Both the mikrotik and my vps have public addresses. I have tried both with windows (default vpn client) and ubuntu (using nmcli). ports 500,4500 and 1701 are enabled on the server.
The ipsec sessions seems to succeed but than immediately closes. when packet sniffing on the client i see the the ISAKMP Session start successfully but then when my client sends ESP packets he gets no response from the l2tp server. What could be the issue with the l2tp server?
here is my l2tp server
interface/l2tp-server/server/print
enabled: yes
max-mtu: 1400
max-mru: 1400
mrru: disabled
authentication: chap,mschap2
keepalive-timeout: 30
max-sessions: unlimited
default-profile: vpn_profile
use-ipsec: yes
ipsec-secret: <secret>
caller-id-type: ip-address
one-session-per-host: no
allow-fast-path: no
l2tpv3-circuit-id:
l2tpv3-cookie-length: 0
l2tpv3-digest-hash: md5
accept-pseudowire-type: all
accept-proto-version: all
Iv’e attached some logs for reference.
14:08:11 ipsec,debug type=Encryption Algorithm, flag=0x8000, lorv=3DES-CBC[142/1872]
14:08:11 ipsec,debug type=Hash Algorithm, flag=0x8000, lorv=SHA
14:08:11 ipsec,debug hash(sha1)
14:08:11 ipsec,debug type=Group Description, flag=0x8000, lorv=2048-bit MODP group
14:08:11 ipsec,debug dh(modp2048)
14:08:11 ipsec,debug type=Authentication Method, flag=0x8000, lorv=pre-shared key
14:08:11 ipsec,debug type=Life Type, flag=0x8000, lorv=seconds
14:08:11 ipsec,debug type=Life Duration, flag=0x0000, lorv=4
14:08:11 ipsec,debug transform #5 len=36
14:08:11 ipsec,debug authmethod = pre-shared key:pre-shared key
14:08:11 ipsec,debug dh_group = 1024-bit MODP group:256-bit random ECP group
14:08:11 ipsec,debug -compare proposal #3: Local:Peer
14:08:11 ipsec,debug (lifetime = 86400:28800)
14:08:11 ipsec,debug (lifebyte = 0:0)
14:08:11 ipsec,debug enctype = 3DES-CBC:AES-CBC
14:08:11 ipsec,debug (encklen = 0:128)
14:08:11 ipsec,debug hashtype = SHA:SHA
14:08:11 ipsec,debug dh_group = 2048-bit MODP group:256-bit random ECP group
14:08:11 ipsec,debug -compare proposal #4: Local:Peer
14:08:11 ipsec,debug dh_group = 2048-bit MODP group:2048-bit MODP group
14:08:11 ipsec,debug -an acceptable proposal found-
14:08:11 ipsec,debug -agreed on pre-shared key auth-
14:08:11 ipsec,debug ===
14:08:11 ipsec,debug new cookie:
14:08:11 ipsec,debug <cookie>
14:08:11 ipsec,debug add payload of len 52, next type 13
14:08:11 ipsec,debug add payload of len 16, next type 13
14:08:11 ipsec,debug add payload of len 20, next type 0
14:08:11 ipsec,debug seen nptype=20(nat-d) len=24
14:08:11 ipsec,debug succeed.
14:08:11 ipsec,debug <l2tp_server> Hashing <l2tp_server>[500] with algo #2
14:08:11 ipsec,debug NAT-D payload #0 verified
14:08:11 ipsec,debug <my_server> Hashing <my_server>[500] with algo #2
14:08:11 ipsec,debug NAT-D payload #1 verified
14:08:11 ipsec NAT not detected
14:08:11 ipsec,debug 01000000 41267826
14:08:11 ipsec,debug use ID type of IPv4_address
14:08:11 ipsec,debug generate HASH_R
14:08:11 ipsec,debug add payload of len 8, next type 8
14:08:11 ipsec,debug 68 bytes from <l2tp_server>[500] to <my_server>[500]
14:08:11 ipsec,debug 1 times of 68 bytes message will be sent to <my_server>[500][92/1872]
14:08:11 ipsec,info ISAKMP-SA established <l2tp_server>[500]-<my_server>[500] spi:<spi>:<cookie>
14:08:11 ipsec,debug type=SA Life Type, flag=0x8000, lorv=seconds
14:08:11 ipsec,debug type=SA Life Duration, flag=0x0000, lorv=4
14:08:11 ipsec,debug type=SA Life Type, flag=0x8000, lorv=kilobytes
14:08:11 ipsec,debug proposal #5 len=52
14:08:11 ipsec,debug begin.
14:08:11 ipsec,debug seen nptype=3(trns) len=40
14:08:11 ipsec,debug transform #1 len=40
14:08:11 ipsec,debug type=Encryption Mode, flag=0x8000, lorv=Transport
14:08:11 ipsec,debug type=Authentication Algorithm, flag=0x8000, lorv=hmac-sha1
14:08:11 ipsec,debug pair 1:
14:08:11 ipsec,debug 0x81d7260: next=0 tnext=0
14:08:11 ipsec,debug proposal #1: 1 transform
14:08:11 ipsec,debug add payload of len 64, next type 10
14:08:11 ipsec,debug add payload of len 24, next type 5
14:08:11 ipsec,debug add payload of len 8, next type 5
14:08:11 ipsec,debug encryption(aes-cbc)
14:08:11 ipsec,debug hmac(sha1)
14:08:11 ipsec,debug call pfkey_send_update_nat
14:08:11 ipsec IPsec-SA established: ESP/Transport <my_server>[500]-><l2tp_server>[500] spi=0xbd594d1
14:08:11 ipsec,debug pfkey update sent.
14:08:11 ipsec,debug call pfkey_send_add_nat
14:08:11 ipsec IPsec-SA established: ESP/Transport <l2tp_server>[500]-><my_server>[500] spi=0x6ba1141c
14:08:11 ipsec,debug pfkey add sent.
14:08:47 ipsec,debug hash validated.
14:08:47 ipsec,debug begin.
14:08:47 ipsec,debug seen nptype=8(hash) len=24
14:08:47 ipsec,debug seen nptype=12(delete) len=28
14:08:47 ipsec,debug succeed.
14:08:47 ipsec,debug <my_server> delete payload for protocol ISAKMP
14:08:47 ipsec,info purging ISAKMP-SA <l2tp_server>[500]<=><my_server>[500] spi=<spi>:<cookie>.
14:08:47 ipsec purged ISAKMP-SA <l2tp_server>[500]<=><my_server>[500] spi=<spi>:<cookie>.
14:08:47 ipsec,debug purged SAs.
14:08:47 ipsec,info ISAKMP-SA deleted <l2tp_server>[500]-<my_server>[500] spi:<spi>:<cookie> rekey:1
