Error connecting to Mikrotik for mac
After disabling ports on the master port in the main menu “Quick Set” WinBox appears option “Bridge All LAN Ports” after it runs, lost access Mac but access over IP.
By comparing the changes after the options, firewall rules mixed and partially changed, but putting them in the original position - the problem is not solved.
Where else can vary depending on the precipice of which can access Mac?
ERROR to MAC
WORK to MAC
