Error: Empty Flow
If you receive the message
Error: Empty Flow (or something along those lines), check your PPP settings. If PPP has been set up to use a local or remote IP pool that no longer exists, you’ll have this problem.
(added because I didn’t find any results when I searched for this error earlier)
-=Russ=-
It can also be caused by not having the “flow marker” set in the Hotspot profile properties pane.
I think that might be related moreso than the PPP stuff (though that was also a problem last night).
-=Russ=-
