Error Fetch file Downloaded What Kind error is it ?
That’s not an error, it’s an info … and probably it indicates that your router is fetching some file from some script … As you don’t seem to recognize the activity it seems like your router had beed compromised and you should do something about it (the best action course would be save config to an ASCII export using “/export” command -just to have reference about old config -, netinstall ROS and adapt default configuration … and make sure firewall changes don’t expose router to attacks, default firewall is quite sane).
