"error fetching data" IE7
This is the message which i see when use IE7 final and User Manager
Confirm. Yes, me too.
The same error User manager 2.9.34
already fixing it (well not exacly it, but making a workaround for broken IE7)
Broken…
IE…
Is there a relationship? :confused:
If it is MS it probably is… :unamused:
If you go in the settings and advanced scroll down to security
Turn off Enable Native XMLHTTP Support
You will not get these errors
edit: fixed in next RouterOS
Hai, Userman... :wink:
i hope only me had bug or...... see this picture for example, when you are open any detail windows but the 'border' is not complete, i did do try other browser is not any problem, only in IE7 is not complete...
yes, we used lates updates ....38 on x86 system-6lvl
anyone else has like that's, i am so sorry green color is sensitive cases and i think for me no big problem, just want to you know
regards
Hasbullah.com
Hi, I have this error with ROS 3.10 and firefox 2.0.0.14..
how can I fix it?
Thanks,
Martín.
