hi…
my big dilema is problem with web proxy in mikrotik routerboard,i did all
configuration right according to mikrotik manual but users keep
recieving this error while they are surfing the net:
gateway time out Your cache administrator is webmaster . . .
there is no problem with disabled webproxy.
please if anyone know the answer help me to solve problem.
try changeing the serialized connections. i have found that that does sometimes have an influence, also make sure that your dns is correct on the tik, proxy has a few things that could influence it, but i run a quite a few native once without cache around a lot of our clients.
Hi
please send your configuration and then we can better help you my friend.
in general when get gateway timout error its a problem between mikrotik and the destination web server or site…
I have the same reason for this error since ros 5.09 before that there was one or 2 things that you could do, but since they changed the interface its been working very well.
i am suing webproxy in routeros for many years but have not any problem…its work very well.
