Error in script
Can anyone see why this isn’t working? I have tried putting () around it and that won’t work either. I am out of ideas.
set 45 name = [:pick [/queue simple get 45 name] 0 28]."-RES"
Or if this doesn’t work is there any way and can take two variables and add them together.
:local v1 “firstname”
:local v2 “lastname”
:local FN v1+v2
I tried the + and the . and I can’t get either of them to work.
For anyone else that needs this I got it figured out.
:set name ($v1 . $v2)
Right :wink:
And for your first question:
You cannot use item numbers (like the 45) in scripts. You have to use the “find” command to find the entry you want to work with using some “find-able” identifier (which could include a comment you put on this very specific entry).
Just for example:
/queue simple set [/queue simple find target-addresses=192.168.1.17/32] name = [:pick [/queue simple get [/queue simple find target-addresses=192.168.1.17/32] name] 0 28]."-RES"
Does that help?
Best regards,
Christian Meis
