Error in Winbox 3beta at Ipsec Policy
A Ipsec Policy can’t be configured because the priority isn’t set “ingeger in range [0;-1] expected”, even it is set to “0”. The config with Winbox 2 oder webfig shows the correct priority without errors.
it is a known issue and will be fixed in the next beta
This is still an issue. When will a resolution be released?
I have 3.0 RC6, and it doesn’t show IPSEC under IP at all, at least not on RouterOS 5.22
Connecting to the same mikrotik with Winbox 2.2.18 works fine, IP->IPSEC exists.
