Error installing Dude Client
After downloading the current and bug fix versions of the Dude Client for Windows and attempting to install it we get an error message “Error Opening file for writing” Options are abort, retry or Ignore. This happens on both Cure=rent and bug fix versions. I have even tried opening the downloaded file as administrator..
Any thoughts?
Dude v6
6.39.3 (Bugfix only): https://download2.mikrotik.com/routeros/6.39.3/dude-install-6.39.3.exe
dude-install-6.39.3.exe.sha256
7a8ee9e67c5977f90c5316450ad2be50c5fb0976f30ab6fbb434f85f85561d23 *dude-install-6.39.3.exe
6.40.4 (Current): https://download2.mikrotik.com/routeros/6.40.4/dude-install-6.40.4.exe
dude-install-6.40.4.exe.sha256
35cbaed1c3b94e0df38e6120d7ba0292126bd48f0d2bfb214862d29d9dda285a *dude-install-6.40.4.exe
Both versions were verified now with Windows 7 Ent SP1 - x64:
  1. Downloaded.
  2. Installed.
  3. Started.
  4. Closed.
  5. Uninstalled.
Which Windows version do you use?
Thank you!
Windows 7 Professional 64 bit
May you try to install Dude client on another system?
Thank you!
