I’m using a Mikrotik RB751U-2HnD with an old firmware 2.38 (i can’t update it) and I found a problem during the execution of this command (on Terminal):
:tool fetch mode=ftp address=“IP” src-path=“/cloud/version.txt” dst-path=“/currversion.txt” user=“username” password=“passwordftp”
It give me the following error:
failure: maximum connection count reached
I tried also with another Mikrotik same of the previous ones and give me the same error.
So after that I tried the same command with other Mikrotik RB951Ui-2HnD with a firmware 6.38 and works correctly.
Can you help me please?
Thanks,
With best regards,
Marco
