error on mikrotik rb1100ahx2
hey guys m getting this error m using
echo: system,error,critical login failure for user admin from 70.45.117.131 via telnet
Even my dhcp server is also not working.
pls help me to resolve it
That error show you that somebody try to connect at your router through telnet.
For the second issue paste your config . (Enter in terminal, write “export” and paste the code) . The easiest way for making router to work is to configure due “Quick set” option.
