Error router os
help me, I just installed a mikrotik ssd on my pc, my pc is intel core i3 10105f with msi b560 motherboard. but when booting bugs and errors appear. how to solve it?
I’m sorry to hear that you’re experiencing issues with your Mikrotik RouterOS installation. There are a few steps you can try to troubleshoot and resolve the issue:
  • Check that your computer meets the minimum system requirements for running RouterOS. RouterOS is a resource-intensive operating system, so it is important to ensure that your computer has sufficient resources (such as CPU and memory) to run it properly.
  • Make sure that you have downloaded and installed the correct version of RouterOS for your device. RouterOS is available in several different versions, each of which is designed for a specific type of hardware. Be sure to select the version that is appropriate for your device.
  • Check for any BIOS or firmware updates for your motherboard and apply them if necessary. Outdated BIOS or firmware can sometimes cause compatibility issues with RouterOS.
  • Try booting RouterOS in Safe Mode by pressing the “Esc” key during boot. This will boot RouterOS with a minimal set of drivers and services, which can help to identify any issues with hardware or software compatibility.
  • Check the RouterOS log files for any error messages that might provide clues as to the cause of the issue. The log files can be accessed through the RouterOS web interface or by using the “log” command in the RouterOS terminal.
I hope these suggestions help you to resolve the issues you are experiencing with your RouterOS installation. If you continue to have trouble, you may want to consider seeking further assistance from the Mikrotik support team or a qualified Mikrotik network engineer.
I am also confused, this is the message that appears.
Loading system with initrd
BUG: soft lockup - CPU#6 stuck for 22s! [ Swaper/0:1]
Process swaper/0
