i try to setup email notifications, also sending backups to my email.
Problem is, when i try to test sending email i getting those error: https://www.dropbox.com/s/ecqmze15ecy4l5a/mikrotik.JPG
But TO address is 100% correct also login data for smtp.
Anyone know where is the problem?
It`s 751G-2Hnd model with 6.0 version of router OS.
That error could be because the “to” address is not valid, or it is not an address (domain) handled by that email server, and you do not have permission to relay on that server. It appears you are sending to the email address “test”, not “test@yourdomain.com”.
You can see more about the transaction in the log if you enable verbose logging.
thank you for response and help.
Something weird happen, when i wrote what you said, i see more logs, but all pass ok? :S
Any way, working now thank you!
Can i ask you one more thing?
How to enable logging for firewall?
and how to disable now additional logging for email?
