error sending email
Posted: Fri May 06, 2005 9:37 pm Post subject: email error
cannot send email , i keep getting
system error error sending email . error connectiing to server
what does this mean and how do i correct the issue.
the script i am using for testing is this one
export file=BackUp; /tool e-mail send file=BackUp to=83180971xx@vt
ext.com subject=([/system identity get name] . " " . [/system clock get time] . " " . [/system clock get date] . " Backup");
i have tried other email addresses same issue . i think i am setting something incorrectly .
Randy
Just a few ideas:
is the DNS service configured?
firewall configuration
mail server may require authentication
Eugene
i figured it our . what i was doing or not doing was telling my MT to send thru a particual server . . i was not specifing server=ip or server.
atleast this fixed the issue.
i got anoter question . is it possible to send a secure email . our emailservers require authentication . i bypassed it for my email address but this is really not the best way to fix the issue. can we send user name and password securely to authenicate ?
Randy
no SMTP authentication is possible, sorry.
I haven’t actually tried this but you should just be able to use the SMTP server that handles mail for your domain to receive a message from MT without authentication. For example, when someone sends you a message from say, anyone@yahoo.com, they do not know the user name and password for your SMTP server, but the server accepts the message if the receipient is local. It should only be relaying that requires a password e.g. anyone@yahoo.com asks your SMTP server to forward a message to anyone@google.com. This is what you are doing when you use your SMTP server to send email out.
So, try setting the server in MT to the SMTP server which handles mail for your domain. It should work without user name and password.
that does work . but our server is setup with if local but not authenicate reject. just more secure. but i did test it that does work.
Randy
Thanks. Good to know it works if your mail server allows it.
